Baltic Bandit
Previous Member
- Joined
- Nov 7, 2013
- Messages
- Reaction score
- Location
- Parus
2nd choice is that your requirements are not possible with the amount of sun that strikes the earth
Note: This feature may not be available in some browsers.
Well, those smileys are appropriate. I don't know whether to laugh or cry either.yeah dear i want a set of plans and instructions because i dont have much knowledge about it...but we have to complete our project to get the engineering degree....![]()
We will charge batteries from the solar source...External source doesn't make it Solar powered boat...Zain, if you are going to use a charger and batteries, what do you need the solar for? as PFlados points out, you can easily get a very very powerful motor and rechargeable batteries that can drive a 1 meter boat at 80kph. http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LZ1007**&P=0
Then glue a cheap solar panel to the top of it and call it good to go.
What you have left out is the other design criteria. What defines "success"? Here I made a mistake. When you wrote "solar powered" - I assumed that you meant
"no external power source other than solar".
If you can charge the batteries from an external source - the rest doesn't matter.
it will be like thatZain, if you are going to use a charger and batteries, what do you need the solar for? as PFlados points out, you can easily get a very very powerful motor and rechargeable batteries that can drive a 1 meter boat at 80kph. http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LZ1007**&P=0
What is it you will be engineering?
ok then if you are using the solar as a recharger, then as an engineer - what is the correct design parameter question to ask here? (Socratic dialogue here)
So I gave you drag formulas up front and some links to them
