William George
- Mar 4, 2013
- London
A question for sportscruiser hull designers out there! The question is in relation to a boat approx 11.5 m long planing hull with displacement approx 7500 kg with 500+hp
I am told by the major international boat builder of this craft that their brand new hull designs require full negative trim on the twin sterndrive installation(-5') and most of the negative trim on the QL interceptors to achieve it's quoted top speed, even with very light load and fuel aboard.
I am a qualified engineer but not a naval architect/designer, and my instinct is that if this is true then the hull design is not achieving an adequate pitch position to obtain maximum speed with it's recommended power installation, without drag inducing full negative adjustments on the sterndrive trim and interceptors.
My understanding is that these device adjustments should be for assistance in uneven or stern boat loadings, early achievement of planng speeds or to effect more comfortable ride in differing sea conditions.
In which case if the builder's statement is true it would look to be assisting for inadequate hull design or/and underpower installation. Is this correct? Do modern boat designers build in this way? If so, why?
I'd appreciate some qualified opinion on this issue.
Many thanks
Many thanks
