BlueBell
. . . _ _ _ . . . _ _ _
- Joined
- May 7, 2017
- Posts
- 3,445
- Reaction score
- 1,323
- Location
- Victoria BC Canada
Note: This feature may not be available in some browsers.
Fixed ballast or centerboard? The fundamental problem is that caulked carvel is heavy, so you must go to tight seam, batten seam or double planking of maximum 1/2 inch (12mm) thickness to lighten the boat. Not many people left willing to do that.
The australian 18ft open boat would be a possibility, it's reported to plane in the right conditions. Definetly an inspiration for the rig. About https://www.openboat.com.au/about.html
A one off most likely, if i can find a design and modify it it would be good. Ideally i would find a modern available design and modify it for traditional construction
Why do some people still build that way and find buyers if it is "inferior" ?Why Do you want to build it with traditional plank on frame, a inferior building technique from ages ago?
Have Fun, Michel
