Interesting conversation!
Trim Tabs on a well designed hull allow the hull to run at its optimum running attitude over a broader range of speed, sea conditions and weight distribution.
Far from band-aides, they allow the good characteristics that a designer has developed to work in a larger envelope than a "static" design.
For example if the boat can plane at lower speed and still keep its bow down cutting an oncoming chop it is essentially running on its lines and the good characteristics of its hull design are working.
Calling Trim tabs a crutch for bad design (if it is a good design to begin with) is like faulting an aircraft designer for including flaps for low airspeed performance.
Tom McGow
Bennett Marine
Very well summarized, Tom! I heartily concurr. For almost 30 years, we've used trim tabs to make good designs perform better and bad designs perform "good enough". It's a rare vessel we work with that does not have trim tabs or interceptors on the transom..or end up with them eventually. SWATHs and hydrofoils being about the only exception.
