... but I'm more into building a reliable database ...
... database to be able to study and compare...
...I also believe that through time the numbers change as the trends change so it would be good to track those changes to be "up to date".
.... I also believe that through time the numbers change as the trends change ..
What is the availability of data on hydrostatic characteristics of vessels to third parties, ie neither the designer, builder or owner?
It is only as reliable as YOU wish to make it. It is your database so you're in control of its reliability or otherwise, no one else!
So the database (that you want) is ostensibly a means for you to perform some kind of statistical analysis?
This does indeed suggest that you're more interested in the 'numbers' for a statistical analysis, than real Design per se. An analysis of the type you are eluding to, is for those without any knowledge of said design that is being requested. Hence the need to "get some numbers" as your starting point. Remember, it would only ever be a starting point, not the end point for your design. It is a good way to start, but don't forget, these "numbers" only convey to you, just that - numbers. It is not a finished or complete answer/design.
Trends has 2 different meanings here.
1 - as fashion. Something that is flavour of the month, it becomes a 'trend'...then a few months later or so...gone.
2 - a statistical definition, implying a suggestive route/answer between sets of or beyond sets of data as such.
If 1, then these becomes statistical anomalies in your database and without knowledge of the designs and why they are as they are, it'll confuse you.
If 2, it just provides you with possible options which lay outside your set database.
I would suggest, you are overthinking this database and its importance. The more designs you do in your career, the more you'll understand that the database of previous designs, is a record, a time line of information from start to finish of the hows and whys and what did or didn't work, and not a series of absolutes, as just 'pure' numbers implies.
Speaking as an ordinary (not naval type) engineer. For your first professional project focus on your systems and project management. Project filing, drawing standards, revision and change control, quality control, effective communications with your client and suppliers etc.
Until you have several designs complete you won't really know what's worth comparing (from experience)
Trying to create a multi factor analysis to compare objects made up of multiple 3d surfaces all operating with different mass properties in different fluids will take more work than your design. And you wont know if it works until you have completed at least two designs.
Spreadsheets like excel are good for analyzing data but have little integrity for data management and not good at creating standard reporting and data entry.
For storage of basic project and design data you could use ms access but a learning curve if you haven't used it before .
Good luck with your project.
...May I ask which type of vessels do you design?
..Until you have several designs complete you won't really know what's worth comparing (from experience)...
Hello everyone,
I'm creating my design database. Being a very important tool in the process for successful developing of new designs I want to learn more about how to make it in a proper and efficient way. How do you usually do it?
Anything from 5m up to around 70-80m, fast ferries, paramilitary boats, crew boat, patrol boats, house boats, link spans etc..
The thing about a database, as I have noted previously, it is all about what YOU want the database to be.... Fredrosse above notes the parameters that he is interested in. Thus what are yours?
But a database like these, are just a series of absolutes. They provide a set of parameters of "similar" types of boats. They are useful for initial guidance, especially in the absence of any starting point of your own.
But the problems is, as noted above, lets say you want to design a fishing boat. The client says I want a boat that is 20m long and does 35knots. You search your database of Fishing boats, and find that there are none that fall into your client's requirements all are say only 15-20knots - so, what do you do?? Or another client asks for a fishing boat of say 20m, but carrying 100 tonne payload. You search your database again and find that all the fishing boats in the 20m range have payloads of say only 20 tonne....again, what do you do? Do you say to your client - sorry it cant be done, because there are no other fishing boats of that speed, or that payload?
Of course not. But that is the point of the database, it is just a series of absolutes that convey nothing other than design and requirements, the SOR, of other clients, not yours!
As JRD notes:
And so after a period of time, you will start to use that database less and less because you have your own, which also has your own inputs and history of the hows, whys and whens. The important parts of the design that are not so easily tabulated in a spreadsheet. So the database becomes your own database of your own designs which since you have designed them, you have, or should have, near instant recall of what does or doesn't work easily and satisfies an SOR - that's called experience. And if an enquiry and requirement, the SOR, sits outside your now full database of your own deigns, then like the example above...say a fishing boat of 20m carrying 100 tonne....your knowledge and experience of DESIGN, will guide you of how to design it. The database in that sense then becomes superfluous!
So a tabulated database of other people's designs for other people's requirements is interesting in itself....but how relevant is it to your client and how much will it really assist you in the end? Because take it to its next logical conclusion....if there is one design in your database that fits your client's perfectly...do you copy it...if so, you may be liable for IPR/copyright issues, or, just ask that designer for a copy of the design and pay them royalties?
Or...
...just use your own knowledge and experience from previous designs...and design your own! As a naval architect, that is what you are trained to do...DESIGN.
It is worth remembering here what some call the spiral of the design process, which means that, starting from certain values, the project revolves around itself, changing and refining the initial values. And I say this because I don't think that starting with certain relationships between the different dimensions and the various parameters that define a project is a serious mistake, but quite the opposite, is the procedure to follow.
What are the correct relationships? Sales values, / published values are invariably not correct, I would not say so much, but that does not mean that they do not serve to establish initial starting values?, at all. And, on the other hand, how many designers, without 30 years of experience, make great designs? Well, I'm going to answer: the majority.
So, @Robinfly, go ahead with your database project and don't let yourself be influenced by negative opinions that have no basis. If what you want to do is too complicated, you will realize it yourself.
