Mr Efficiency
Senior Member
- Joined
- Oct 17, 2010
- Messages
- 10,374
- Reaction score
- 1,051
- Location
- Australia
Better to test all aspects, for sure
Note: This feature may not be available in some browsers.
The plywood is marine grade, but made for forming concrete. The coating is to prevent adhesion, which is a problem if you want to bond anything to it.
Thanks Gonzo!! My main fear was bond problems with plastic. Epoxy will probably not bond to it and even if removed, a glue for the adhesion may be lower strength than a 2000 psi epoxy bond...The plywood is marine grade, but made for forming concrete. The coating is to prevent adhesion, which is a problem if you want to bond anything to it.
Not after Gonzo's post. Forget about that concrete forming board rebranded as marine ply..As fallguy indicated, conduct a test of all aspects that concern you, allowing a reasonable cure time for any epoxy adhesion test
Not really. The plywood gets reused and usually stored outside in the weather. Marine plywood will have a longer service life.Bizarre that they would make marine grade ply for form work.
