Branding on plywood-need to remove?
mariobrothers88
Senior Member
Joined
Sep 9, 2020
Messages
215
Reaction score
10
Location
San Diego, CA
Hi guys the local marine plywood is made by this Chinese manufacturer called consmos and they have their branding all over one side of the plywood. Do I need to remove this branding before I put fiberglass and epoxy over it or can I just fiberglass and epoxy directly over it? See attached photo
Thanks for any advice or input!
The store says it's a plastic protector that's important for the protection of the wood and I shouldn't remove it. Can I fiberglass and epoxy over this plastic protector? I can remove it pretty easily with a planer but I'm worried about taking too much of the wood and exposing the inner plies. This is what it looks like after planing.
Horse pucks.
It must be removed.
Don't believe me? Test it. Bond a piece of 2x4 on edge, not end to a piece of scrap plywood and a piece to the plastic marketing materials. They should be about 4-6" long chunks.
Then wait a day.
Then apply pressure to the bond by hand.
The plastic will either peel or the 2x4 will shear away from the plastic. The wood to wood bond, I can almost guarantee is stronger.
I wonder whats underneath that plastic. Maybe I'm just getting paranoid in my old age. It's 99.99% likely that the plastic is just glued on somehow and not nearly as secure as an epoxy or even a polyester bond. Why would the manufacturer do that?
It increases their costs and degrades the product.
Over here, I see that in the hardwares. They call it formboards, sometimes phenolic board. It is a cheap marine plywood with waterproof coating. The coating is part of the plywood and it is meant to be a protective layer when they pour the cement mix. It is part of the plywood.
These are called overlays here in the states. They can be pretty much anything, but they are intended by the manufacturer to stay there. The purpose is usually cosmetic or to provide improved weather protection during construction - for instance, roof sheeting and floor sheeting might have this.
https://www.murphyplywood.com/pdfs/softwood/HDO_MDO_Product_Guides.pdf
Glen L.com has a thread about it - What The Heck Is MDO Plywood - Glen-L.com https://www.glen-l.com/phpBB2/viewtopic.php?t=1185
MDOs and HDOs are quite a bit more expensive than regular ext grades.
I'd go direct to the manufacturer, likely through who you bought it from.
Seems a shame to pay for something you have to remove.
Doesn't add up.
It's tough to be sure from a photo but it doesn't look like MDO to me.
Hey guys this is my other option as a marine grade plywood . It's more expensive than the black consmos marine plywood by about $10. It only comes in 3/4" and they say it's from Canada and it's better quality than the consmos one. But they didn't know the actual species of the wood and they really didn't know what they were talking about. This marine grade plywood looks to be poorer quality with more small voids and defects along the edges than the Chinese consmos one.
Here are the photos of the more expensive Canadian marine plywood. Due to the poor quality I think it's better to go with the Chinese consmos black one and remove the black plastic with a planer. But which one would you guys go with?
It does not sound practical to me. to be planing it off, you will go mad before the job is finished ! Will it peel off ?
What you might try, if determined to remove it, is the mesh sanding discs that can be fitted in larger sizes to a 7" sander/polisher, if the plastic is softer than the wood, it might work, but if the other way round, no. Someone may know the proper description of this
The beauty of it, is that there is no gouging or scarring of the surface, but like I say, if the plastic is hard, probably not going to work.
Roseburg?
You need to buy a sheet of each and test the Chinese stuff for bond like I said, epoxy a 2x4 about 6" long to the facing. Wait 24 hours and try to break it off. More likely than not, the 2x4 will either peel the plastic or off the plastic, neither is great.
for the Canadian brand, small voids are typical and no big deal, but the stuff must pass a boil test...hard boil in water for 30 minutes and make sure the glue hasn't failed
if you decide one is not what you want, use it for cabin settee out of the elements..
