Yes, that's what I was thinking, now let's make everything as light as we can.
1. Underwater, 3m2: cedar core 7kg, balsa core 2.7kg. 200g fiberglass outside (for abrasion) but 100g carbon inside. Plus epoxy = 400x3 + 200x3 = 1.8kg. So cedar core 7+1.8= 8.8, balsa 2.7+1.8=4.5kg. We can even go to 8mm balsa for better stiffness and the core would be just 3.6kg.
If you can promise not to hit the bottom or drag the boat on shore we can think of 100g carbon outside also, maybe with an additional fiberglass patch in the bow area.
2. Plywood, 7.6sqm. We must divide this into sections, because fiberglass isn't needed everywhere. We put 200g on the outside of the vertical forward part for scrapes. We put 100g carbon on the underside of the wing, because that's where the loading will be. Inside we just paint the plywood with epoxy, no glass at all. Maybe 20kg all in. We can also play a little with the deck and inside part of the wings if necessary.
Even with a cedar core lower hull, it's under 30kg.
3. Foam: we most certainly don't fill the entire volume with it, that would be crazy. To determine how much foam is needed you take a piece of the 4mm ply and cut a square that's just a little bigger then your shoe size (30x30cm or 50x50cm depending on how big your feet are). Then you glue 5cm thick xps strips around the edge, place it on the ground and step on it with one foot. If it doesn't crack you repeat with a bigger piece of ply. If it cracks you add another strip in the center and see if it cracks. Then you sit down on the test piece, but usually people's buts have a bigger area then their feet, so it shouldn't crack from sitting. The determined spacing will be used to make a xps grid between the two layers of plywood. This is just under the cockpit and between the wings, the forward part of the boat remains hollow.
I will write a little about how I think Gary did his boat later tonight.
Thank you, Rumars, these are some really good tips. But like I mentioned before, balsa is not available where I live, only very small pieces (typically 10x20 cm sheets, sometimes a bit larger) get imported in Lithuania. As for cedar, I called the place that I found that imports it - all would be great, except for the price, which is astronomical. 4600€ / m^3, or ~$150 per cubic foot. And they only sell 0.5 m^3 minimum, no scraps or off-cuts. And they are the only dealer. So yeah, I guess this option is out. I also took a drive to 3 lumberyards that sell aspen, and the situation is pretty bad too. The quality is total crap (warped, cracked), and the price is 2000 € / m^3, which is also VERY expensive compared to construction lumber which is ~300 € / m^3. Plus, they only sell aspen in lengths of 1.5 or less, which means at least 4 scarfs per boat length. The weight savings with aspen are very small in comparison. I called a few more lumberyards, described what I saw and asked if they have any better stuff, and the answer is no. It is what it is, I guess.
So, cedar is out, aspen is expensive, extremely bad quality and would require tons of scarfing to get anything usable. Couple that with the complexity of building the mixed-method boat, and this option is starting to lose it's appeal...
I am sorry to be shooting down your ideas, guys, I really appreciate the time you already invested into guiding and helping me with this project, and I am looking for ways to make your suggestions work, but the reality of the material unavailability keeps cutting me off at every turn. I will continue searching for any suitable strip planking materials from what you suggested, but it's looking pretty bleak at this point.
My earlier post regarding the comfort of sitting on the wing may not have been particularly clear.I hope the attached rough sketch will be helpful.The transverse wing frame will obviously need a small batten attached to the top edge for the deck to bond to.
Thank you for making that sketch, I see your point now. Truth be told, I never hike like that, I always keep my butt on the edge of the boat, which is why I'm making the boat with these wide flares. The reason for that is because I almost exclusively sail inland (lakes), where wind conditions are extremely shifty and unpredictable, often with little indication of changes on the water surface due to surrounding terrain (hills, tall trees, etc.). This means that if you hike in the position you drew, and the wind suddenly dies, you fall over to windward, as you have no leverage to get back inside the boat (trying to do so induces a turning moment which turns the boat over even faster). With your butt on the chine, you can slide longitudinally and very fast, avoiding creating that turning moment. Your point is still valid though, and I'll see if I can make that batten wider.
The hull presented in post #70 has one major defect,there is only one buoyancy compartment.It needs more,ideally two more so that the boat will float reasonably well if damage should occur while sitting on those rocks we have been warned about.I would suggest adding another transverse frame in the wing area too.The mast step and retaining collar aren't shown and yet they will be the most highly stressed parts of the boat.The comment about ugliness needs to be tempered with the realization that for racing purposes,speed is more useful than beauty and then.as if by magic,the boat that succeeds on the race course will be considered beautiful.Speed of building is quite useful too and that is helped by keeping things simple unless there is some good reason for complication.
Well damn, I guess I've been lucky to have never damaged any of my boats to THAT extent
I guess the compartments could be separated, but it would make getting water/moisture out much more difficult during normal operation. I typically have a single continuous compartment throughout the boat with hatches at either end, so the moisture can be driven through A->B point circulation.
Ok, here are my thoughts about tortured ply, and how I think Gary was able to obtain that shape. First of all is experience and a good eye, he is able to visualize the shape the ply will take. Second is a long slender hull with almost straight topsides and not a lot of rocker.
There is plenty of separation between bends in different directions, there is no true compound bending, there are flats in between, even if they aren't all that obvious.
A key to success is probably the dry run, this lets one better plan the individual scarfing locations between sheets.
As I understand it one way of trying out the shape is to build a scale model using a material of similar stiffness. The thin 2mm aircraft ply seems to be a good match of how the real ply might behave, and if changes can be made to the hull to accommodate the bends.
Thank you, I have been waiting for this comment for a long while now. Very good observation about separation of different bends. I am just not sure how to achieve that with CAD software when the goal is to have a smooth hull with C2 continuities all over, rather than build it in discrete sections. You said "straight topsides" though, but Gary's hull has something very similar to my flares/wings built into them, bent from the same sheet of plywood. No matter how I look at these pics from these two big threads you and I linked before, I can't quite grasp how could bend directions be separated like you described...
And yeah, I'm all for building a scale model, but without knowing what shape I'm trying to achieve, I can't build the frame, and I can't build the frame without knowing how the plywood will behave. It's a bit of a chicken and egg problem. I still feel that there is a lot to learn here in terms of pure theory so I can at least get in the ballpark for scale model building.
It doesn't have to be flats,a single straight line that is common to one conic element of the panel and it's adjacent conic section would be sufficient and there may be no practical upper limit to the number of conic sections in each panel.The challenge is to form the hull in such a way that the panel adheres to the shape that you would like it to be.It is possible to introduce a small measure of deviation from these ideal conic shapes and this is the torturing process.How much distortion may vary from one species of wood to another and from one batch of plywood to another.Model building is a very good guide,but not an absolute guarantee of success.Thinner plywood may be more amenable to some distortion and will mean that closer supports will have to be provided in stressed areas.To get a good idea of what may be achieved it really is worth seeking out build sequences of Moths from the lowrider era or Int canoes.The Magnum series mentioned throughout this thread had 3mm Okoume/gaboon hulls and no glass sheathing.They did need careful handling but were amazingly fast.They also needed to be built over a well designed male former to ensure fidelity to the design shape.The challenge for this build will be to create the best shape that can be created without requiring excessive construction of a former.The simple solution is to use pure conic or multi-conic shapes and accept the aesthetic compromise while retaining the speed producing shape.The best reference to creating the multi-conic shape that I ever read was in this book ;
https://www.amazon.co.uk/Aluminium-Boatbuilding-Ernest-H-Sims/dp/1574091131
Thank you, the multi-conic method was something I've kept seeing all over, but so far my brain can't figure out how to actually design a hull with just cones (and then slightly deviate as you suggested to smooth things out). That books looks extremely promising. I'm not sure if I'll be able to get it before I have to build this boat (summer is just around the corner, and my feet are burning), but even if I have to save this for the next boat, this resource is very very useful.
EDIT: I found that book in PDF, so I can start reading it now after all. I still bought it to support the author, but I won't have to wait for shipping
Okay, so with the material unavailability, I am unfortunately forced to shelf the mixed-method design for now, and reconsider pure plywood build, as it appears to be the only realistic option right now. That likely means raising the weight limit to 40kg. 4mm Okoume is the lightest and thinnest that I can get. If I can fully uncover Gary's method of achieving these crazy complicated shapes, then I can in theory build the outside/bottom of the boat from a single scarfed sheet of plywood, and use very few bulkheads, like he did. This would yield round-chine hull like I wanted, and considerable weight savings.
If I can't figure it out, then I have to sacrifice round chines and go with stitch&glue, using trapeze bottom with slit V-shaped middle panel, which is heavier due to more filleting and glassing the seams, and probably needs more bulkheads. I'm reluctant to return to this after you guys gave me so much great advise with alternative build methods, but if materials are not available, then I have little choice in the matter.
Anyway, to avoid sitting idle with analysis paralysis, I threw together a design with probably a few too many bulkheads, but structurally it seems to make sense overall. I included the mast supports and daggerboard case for a more complete picture and weight estimations.
Now, for the weight (I'll calculate a bit differently this time), the total dry (no fiberglass, no epoxy) weight of what you see above is 29.5 kg. This includes all the plywood, edge stringer, supports on the keel, etc.
Now, you said not to glass the inside of the boat, so the following numbers assume glass on one side. I'll add epoxy on the inside later.
The bottom of the boat and underside of the flares is 6 m^2. So with 200 gsm cloth that would be 0.200 * 2 * 6 = 2.4 kg.
The top of the flares, the floor, the deck (all the topside) is 5 m^2, so 0.200 * 2 * 5 = 2 kg (this could be either fiberglass or carbon fiber like you suggested)
The total inside area (everything that needs epoxy but no glass) is 13 m^2, so with epoxy at 0.200 g/m^2, that is 0.200 * 13 = 2.6 kg.
Fillets and seam tape probably 1kg more.
Fairing, paint and hardware 3kg.
So in total we're looking at 40.5kg. But this assumes no foam, and I think it is needed for floor support between the bulkheads. There won't be a lot of it of course, not like I've drawn previously. Rumars, I will test the plywood with your method to try and estimate exactly how sparse I can place it. But I assume there will be at least 1kg more.
So, I'm over the raised weight limit by some 1.5kg. I can probably shave that down a little, maybe 0.5kg, but probably not more. I just don't see where else I can save weight, the structure is pretty bare-bones as it is. Maybe one less bulkhead, but bulkhead is just 0.2 - 0.25kg on average.
The design I've showed here has no compound curvature on any panel except the bow deck and the top surface of the flares. These panels will be installed last, when the boat is already rigid, so it should be possible to torture them a little for extra stiffness.
I ordered some 1.2mm model aircraft grade plywood (3 layers) to make a scale model, but it will take a few weeks to arrive. In the meantime, I 3D printed a simple structure with 3 bulkheads and some flat panels separately, to try and get a feel if this shape can be done with stitch and glue.
I didn't do a great job of gluing it all together, but in essence it seems to work, the panels conform to the expected shape with just 3 bulkheads, whereas in my design I have 6. Of course the model is way too small to make any definitive conclusions, it's just 31 cm, I need to make one at least twice as big and use real materials instead of plastic, but this is what I had at hand.
Again, not too happy about having to ditch round chines, but I did try very hard to make this multi-panel hull as smooth as possible, the angle between adjacent panels never exceeding 20°. Hydrostatics need improvement, but it's difficult to get enough displacement without increasing Cp, wetted surface area, and losing fine bow entry angle. Quite close though.
Disp. 140 kg.
LWL 4.42 m.
BWL 0.78 m.
Wet surf. 2.45 m^2
L/D 5.66
LCB 0.43
Cb 0.33
Cp 0.52
Cw 0.64
Entry ang. 16.6°
