How do you lose displacement? Gonna have to explain that one to me.
where is the waterline on the scow?
I am building an ultralight rowing dinghy. Not in the same class as your work. It is also a private design, not yet released to the public and not my design.
This evening I tried to increase the height of the bow, but it did not work, I'll have to try better.
I rised the bottom part of the bow and adapted the curve of the hull starting from midship, but I think I over did it and it become a little odd looking.
When I say that I'm going to loose displacement I mean that if I want to keep the same depth and no trim, I will have to compensate for the part of the hull that I moved up, otherwise the trim wont be zero anymore. CG and Center of Buoyancy would not be in line anymore, the latter moving backward. I guess my terminology - and translation as I'm Italian - is not correct - may be also some concepts - keep in mind that I'm just an amateur designer trying to design my own boat.
The waterline is 7cm (2.7 inch) below the bow (1,107mt depth). How much do you think is should be? I was thinking about trying 12-14cm (5inch), but it just a guess as I do not have examples to follow.
By the way, when I say 'odd looking' I dont mean I dont like it. It is more something like I would not fell safe in that kind of hull. As I said in one of the first posts, this is the first time I design something, and I find it difficult to design something that is not in some way all right to my eye. I guess similar from what I'm used to see.
Probably the scow idea is in this aspect not a great choice, but that's how it all started.
DVV
