sharpii2
Senior Member
- Joined
- May 31, 2004
- Messages
- 2,282
- Reaction score
- 348
- Location
- Michigan, USA
I can not recall the competitor, but it was interesting to see the winner sailed a whole lot more sea miles, than the guy who stuck rigidly to the shortest route. Its much more using weather forcasting with favourable routing when all boats are running displacement speeds.
ULDB do not have to be expensive. Ply on frame 50ft is not in any way "exotic", and the lighter boat needs a smaller rig and sail area, much savings to be had there even if some semi-exotic fabric was put on the hull.
I recently did a bit of math noodling on Displacement/Length (D/L) ratios.
I started out with a boat of the following dimensions:
Length= 34 ft (10.4 m)
Beam = 11 ft (3.36 m)
Displ. = 9,856 lbs (4,460 kg)
Then, I played with its Load Water Line (LWL)
With a 32 ft (9.76 m) LWL, I got
a D/L of 134.
With a 27.2 ft (8.29m) LWL, I got
a D/L of 219
With a 24.5 ft (7.47 m) LWL, I got
a D/L of 300
And
With a 22.0 ft (6.71 m) LWL, I got
a D/L of 414.
And this was with the same Length, Beam, and Displacement.
My conclusion is that a boat with a low D/L can easily require as much Sail Area as a boat with a high one.
And it is likely that low D/L boat will have greater Sail Area than the boat with a high D/L, if it has the same displacement.
This is likely because it cannot only be driven harder, but because probably has greater form stability as well.
This is why I use a ratio I came up with which I call the Heft factor (Hf).
It is determined by taking a boat's displacement volume, multiplying by 20, then dividing it by the square of its Beam, then by it's Length. The resulting product is the rounded down to a two digit number such as: 0.50, 1.0, or 2.0.
A boat can have a high Hf, say 1.5 to 2.0 and above, and a low D/L only if it is very narrow for its length. Rowing shells and maybe kayaks are good examples of this.
A boat can have the inverse of this if it is very wide and short, such as a catboat. It can also have a more common Beam Length ratio of, say 0.30 to say 0.35, but have long overhangs and a short LWL.
Late 19th and early 20th century racing yacht designers were notorious for exploiting this loophole.
