The following is a 45 foot day charter catamaran designed by Morrelli & Melvin for 49 passengers. The cat is 45.3 x 24 foot with a weight of 13,600 lbs and a displacement of about 25,000 lbs. The 54 foot aluminium fixed mast carries a 600 square foot mainsail and a 290 square foot fore triangle with a self tacking jib. The headstay and cap shrouds are of 15 mm 1x19 wire. Superior diamonds are 12mm compact strand, inferior diamonds are 10mm compact strand. All turnbuckles and cables are 316 stainless steel. The hull length to beam is 7.5 to 1. The kickup centre boards draw 6.5 foot when down. As a charter catamaran this boat will sail well, but is not intended to be a high-performance racing machine.
According to the designers much thought went into making this vessel as strong and practical as possible to absorb the punishment of high volume day charter business, to minimize down time and to be easily sailed with a short handed crew.
Schooner Creek Boat Works, in Portland Oregon did the first build. The hulls, decks, bulkheads and bridge decks are a composite of bi-directional and unidirectional E-glass and PVC core, utilizing infused vinylester resin. The hulls will be built on a faired female direct mold joined on hull centerline. Final fairing shall be done with “Duratec” vinylester primer, applied in sufficient thickness to form a water barrier beneath the waterline. Two water tight bulkheads are installed in each hull, separating compartments at each extremity. Ring frames are installed in each hull on 5’ centers between bulkheads. Local laminate reinforcement is added to bow, the centerboard case trunk and rudder area for impact absorption. Bulkheads to be installed on trapezoidal foam sections, to distribute compression loading. Monocoque hull and deck construction, with no mechanical fasteners. The hulls are painted with “Awlgrip” linear polyurethane paint.
This is an interesting design that could form the basis of a good cruiser. The jpegs give the idea.
