If there is one thing that really annoys me in boatbuilding is sanding and fairing to get that really good finish. As Jim Brown of Searunner fame said, do you want to polish your boat to perfection or go sailing. Unfortunately to get the perfect finish it generally involves a lot of sanding. If your building a boat from a mould or using flat panel foam glass techniques you will still be doing a lot of sanding. Even with moulded parts your still going to need tape joints etc that will need to be sanded.
There have been people who have built very large home built boats and they have one thing in common they semi automated the way they faired their boat. One USA guy, Clyde, built almost single handed, a 100 x 40 foot aluminum full wingdeck power cruising catamaran. He had built the shell of the cat then came the minor detail of getting a smooth finish on the outside. After putting a chemical surface cleaner over the entire exterior, Clyde put a 4 to 6 mm layer of Bondo filler on the outside of the cat and start fairing the 14,000 plus square foot. After a very short time Clyde developed 4 different sanding machines to assist him doing the fairing. He in effect had a power assisted long board. Are success! Now we had a good looking structurally sound shell with engines installed. After 5 years of work now all Clyde had to do was shift the 100 x 40 foot cat 85 miles to the water. (Page 177 Multihull Structure Thoughts).
Last year,
Viking Yachts (New Gretna, New Jersey) turned to automation, artificial intelligence (AI), and robotics specialist
Viam (New York City) to help reduce the thousands of hours of manual fiberglass sanding required for its superb finishes. Conversations started in November 2024, and by July 2025 the first custom robotic block sander was installed at Viking and early-stage testing began.
“Fairing is one of the most labor-intensive and critical parts of the build process,” said Daniel Thompson-Rhodes, Industrial Engineer at Viking Yachts and the project lead. “If we can maintain Viking’s standard of finish while reducing physical strain and reallocating our skilled techs to other areas, that’s a win. This isn’t about replacing people—it’s about evolving the process to support them and the long-term quality of the product.”
Viam designed its sanding tool by learning how the best technicians at Viking did the work by hand. That meant avoiding the random orbital sanders that are good for final finish, but less so at fairing flaws out of the molded surface. The Viam tool is essentially a block sander on a robotic arm with a 63″ (1.6m) reach. It requires a skilled sanding technician to operate it, running the machine’s scanners, changing sandpaper, applying dye to the subject surface, identifying areas in need of sanding, directing whether to sand more or less, and approving when a task is complete. Contrary to the hype that AI is completely automating production tasks, this is not a technology you can walk away from and find a perfectly faired surface when you return from lunch. “People should be thinking of them as tools first, robots second,” Horowitz said. “You can instil some knowledge into it and have it repeat tasks.”
This is a step along the way to reduce a time consuming and annoying sanding tasks. It also helps enormously if you work neatly with the basic structure, eg use peel ply when rolling out glass fabric, clean up drips or lumps as you go, do a fairing coat within a few hours of a final glass layup to minimise the sanding required and if possible use clean moulds for parts so there is no requirement to finish the entire surface, just the edges that will be taped in.
The jpegs give the idea of the automated robot. The first 2 jpegs are of the 100 foot catamaran and the sanding long board.
