Looking for a Low-Cost Easy to build multihull sailing design
Discussion in 'Multihulls' started by kekdu, Sep 27, 2024.
Tags:
  1. kekdu
    kekdu New Member
    Hello everyone, as the title suggests im looking for a Low-Cost Easy to build multihull for me and my wife. We are not experienced in building boats. I think around 25 feet multihull will offer us a comfortable space. I'm looking forward to hearing your suggestions and ideas.
  2. kekdu
    kekdu New Member
    Oh i actually deleted that graph but somehow it made its way to this post and cant delete it now xD
  3. Burger
    Likes: 32, Points: 18
    Burger Junior Member
    Richard Woods Eagle 24 fits all your requirements.
    Plenty of information and pics online. Check out the Woods Design website for details. I also recommend reading the articles on his site, there is a wealth of good information and advice there. Also a forum where Eagle builders connect and post pics.
    A good boat from a good designer.
  4. oldmulti
    Likes: 2,265, Points: 113
    oldmulti Senior Member
    Kekdu. What are your skills, can you work with wood, plywood or are you skilled with fiberglass? Do you want to keep the boat on a mooring or trail it home? Do you want a full standing headroom cabin with a galley double berth and toilet? Is it for sailing in a bay or coastal cruising for a week. Do you want to sail fast or cruise along? The answers to these questions will guide people to a better answer for you. Hope this helps.
  5. kekdu
    kekdu New Member
    i have minimal experience with plywood and no expereince with fiberglass but the building will take place on a friends farm so we will have additional manpower and handy people who can join us and another friend who works on huge wind turbines which uses very similar material to modern yachts. I will keep on a mooring. Full standing is hard for me since im 1.94m. I want it for cruising so yes we need toilet/berth. THanks for the help.
  6. kekdu
    kekdu New Member
    Eagle 24 looks like a solid choice. Thanks.
  7. Igor
    Likes: 20, Points: 18
    Igor Senior Member
    Check catamarans by Bernd Kohler, very simple but clever designs.
  8. JimMath
    Likes: 2, Points: 3, Legacy Rep: 10
    JimMath Junior Member
    Sango ( hard chined version) is a great choice I would chose over Eagle myself…Both by Richard Woods
  9. Burger
    Sango and Eagle are very different boats, despite being nearly the same length.
    Sango (hard chine) uses 123 sheets of ply. Eagle uses 42 sheets.
    Sango weighs 0.9 ton, displacement 1.4 ton. Eagle weighs 0.65 ton, displacement 1.25 ton, so 100kg more payload.
    Sango would take considerably longer to build, due to the folding beams and cuddy cabin. On the plus side, comfortable enclosed deck cabin, and easy trailering. (Don't forget to budget for a large trailer and suitable towing vehicle.)
    Eagle is simpler, cheaper, quicker to build. Sango would be more comfortable for a family. Performance/seakeeping would be about the same, excellent as Woods boats are.
  10. redreuben
    Likes: 285, Points: 83, Legacy Rep: 349
    redreuben redreuben
    JimMath likes this.
  11. guzzis3
    Likes: 163, Points: 43, Legacy Rep: 42
    guzzis3 Senior Member
    More galley dine etc than Eagle less hi in hull. 4'...
    Great little boats trimaran or Catamaran at very reasonable
    Double Shuffle 5.6 Good! Small.
    Fish and chips good!
    Siren 8.4: for the experienced builder
    Sailing Catamarans - Gypsy - 8.5m Budget Offshore Cruiser with central cuddy http://sailingcatamarans.com/index.php/designs-2/3-25ft-to-30ft-catamarans-designs/176-gypsy
    GYPSY 28: 6' ! Every thing... $ + hours !!! ....
    Bild 2 hulls make the central cuddy later...year or 2 ?
    2c...
  12. gonzo
    Likes: 2,277, Points: 123, Legacy Rep: 2031
    If you are not experienced in building boats, it will take you several years to finish the project. Ask yourself if the main goal is to learn boatbuilding or go sailing. If going sailing is the goal, a used boat is cheaper and faster.
  13. JimMath
    Eagle does look like a good choice ,if you look on the Woods builders forum,Peet extended his to 25.5’ approx.
    …Peet has some good ideas and photos.
    I have Eagle plans , Sango’s Cuddy appeals to me and as mentioned above you can add a Cuddy in a few years , if TR is Trinidad….
    Eagle is a good choice ….
    Sango hard chine matterial list below from Woods site , ply is about 21 sheets x 2 = 42 ? and lots of timber
    Hull planking 12 sheets 6mm ply 3 sheets 9mm ply (replaces cedar, biaxial glass and some
    Decking 6 sheets 6mm ply
    Timber 2in x 1in 200m 1in x 1in 100m
    NOTE: all plywood to be best quality gaboon (okume) marine grade
    All timber to be best quality softwood eg Douglas fir, sitka spruce, yellow cedar or similar.
    NOTE: Timber sizes are nominal. Planed all round (PAR)
    Glass sheathing 300g glass cloth (hulls) 36q m 200g glass cloth (decks) 12sq m Epoxy 30k counter sunk stainless steel self tappers or gripfast/anchorfast barbed ring boat nails Approx
    Eagle :from Woods site….
    Basic Materials List
    37 sheets 6mm plywood
    5 sheets 9mm plywood
    2in x 1in 200m
    11/2in x 1in 120m
    1in x 1in 50m
    45kgs min epoxy
    1 kg wood flour or similar filler
    20kgs min 200g glass cloth (biaxial +/-45deg recommended for joints)
    2000 stainless steel countersunk screws 3/4in x 6
    filler/paint as required
    All plywood to be best quality Marine grade Gaboon/okoume pl .
    Sheet sizes are 8' x 4'.
    , 2440x1220
    All timber to be at least "Joinery Quality".
    Unless noted otherwise all timber is softwood, eg Douglas Fir, Sitka Spruce, Yellow Cedar or similar.
    A ll timber is "PAR", or "Planed all Round". Thus sizes given are nominal, ie 2" x 1" has a finished planed size of a 45mm x 20mm. (Note: It is usually cheaper t o buy wider planks, eg buy 2" x 1" and cut it in half to create 1" x 1")
    Epoxy glue is recommended for all glue joints as it is gap filling and the strongest and most watertight glue
    List excludes errors and waste
    く Prev
    Nex
  14. luckystrike
    Likes: 43, Points: 28, Legacy Rep: 92
    luckystrike Power Kraut
    Sorry Redreuben,
    but (imho) I do not consider a Scarab to be an easy build. There are way too much planks to cut, fit, glue and sand fair to be simple and fast. For an unexperienced builder too much manhours to build and too much opportunities to make mistakes and up with an unfair boat.
    Have Fun, Michel
  15. redreuben
    redreuben redreuben
    That may be, but your not the OP, so…..
    I’m just providing options, in my observations here builders like $150 plans V $1000 plans, it buys a lot of epoxy.
    But that is not my call.
    dialdan and guzzis3 like this.
