The EC24 power catamaran is from the following web site: Power Cat Boat Plans - Boat Builder Central https://www.boatbuildercentral.com/product-category/boat-plans/multi-hull-boat-plans/power-cat-boat-plans/
The catamaran can be powered by fuel or solar power with batteries. An interesting design and if you want more detail or the plan the above address is an excellent place to start.
The E stands for Electric Catamaran or Economy Cat or Efficient Cat the design is all that. The cat is 29.75 x 8 foot or can be built up to 10 foot wide. The displacement (I suspect is weight) is 2000 lbs with an immersion rate of 295 lbs/inch. Now we get to the interesting part. This cat can be powered by two 5 HP outboards or a single outboard or be solar/battery powered by EG Electric motors like the Torqeedo Cruise R 4.0 “outboards”. Batteries can be recharged by solar panels mounted on the roof or dockside or on the trailer. A small quiet generator can be kept onboard to recharge the batteries. Performance will depend very much on weight. Lightly loaded, with a pair of Torqeedo's 4.0 and two battery sets, the boat will cruise all day long at 6 mph, top speed above 10 mph. With 2 modern 600 watt solar panels charging your batteries you will be able go a long way without recharging. With a pair of small gas outboards 5 HP each, performance will be the same than with the electric motors. With larger gas motors, 10 HP max., the top speed will be around 15 mph with no range limitation.
The build material of the cat is fiberglass epoxy on a plywood core which is stiff and light which helps a relatively efficient catamaran hull. The chine hull section is made of five panels with a narrow bottom. The hulls are fine and the long waterline provides minimum resistance for a given speed.
The thin plywood acts as a core between layers of e-fiberglass in epoxy. The assembly is done by stitch and glue. The E Cats are built in 4 parts: 2 hulls, a set of cross beams and the deck. The hulls are built one or two at a time, the beams and some of the deck furniture are built separately from the hulls. After completion of those parts, the hulls are joined by the cross beams, the assembly is fitted with a deck and deck components are added. The E Cat hulls are built upside down on a jig made from the plywood frames or from throw away molds. The following chart gives the bill of materials for the basic hulls and bridge deck. Any seating and Bimini top is extra material.
Plywood standard sheets 4x8'
12 mm (1/2") 2 sheets
10 mm (3/8") 7 sheets
6 mm (1/4") 11 sheets
Boards and Battens
25 x 75 mm 120 feet
25 x 25 mm 100 feet
Fiberglass fabric 1250 mm wide or tape 150 mm wide (totals)
Biaxial tape 45/45 12 oz. (400 gsm) 1200 foot 366 meters
Woven fabric 6 oz. (200 gsm) 50" wide 105 foot 32 meters
Woven tape 9 oz (300 gsm) 4" wide 19 foot 6 meters
Resin Epoxy, total 35 litres 30 Kg
An interesting design. The jpegs are from the design brochures.
Boards and Battens
25 x 75 mm 120 feet
25 x 25 mm 100 feet
