The ISLAND SPIRIT 410 Catamaran is from Spiritdesigns in about 2017. The cat is a performance cruiser/charter cat that is 41.5 x 23.1 foot and weighs 18,000 lbs with a displacement of 22,400 lbs. The standard aluminium mast is 50 foot high and carries a 576 square foot mainsail and a 320 square foot jib. There is a performance rig option that has a 54 foot mast and a 730 square foot mainsail with a 342 square foot jib. The length to beam on the hulls is 9.5 to 1. The low aspect ratio keels draft is 4.1 foot. The hull prismatic coefficient is 0.624. The underwing clearance is 2.7 foot. The hull freeboard at midships is 6 foot.
The performance of the cat under the standard rig (aimed at the charter market) will be good with these numbers. The performance rig will help improve performance for faster cruising. The accommodation layout gives the clue as to the intention of this design with 4 separate double cabins and 2 full toilets in the hulls in a charter cat configuration. The main saloon cockpit combination will comfortable sit 8 and the galley area is large. I especially like the “roof” solar panel supports over the dual steering cockpit areas. There is a 3 cabin “owner” accommodation option available.
Spiritdesigns generally design in DuFlex glass, Balsa/Foam glass or Plain Foam glass. This cat is described as resin infused foam glass construction. If the cat follows the normal build procedure there will be a lot of flat foam glass or duflex glass panels with a separately built round bottoms attached to the rest of the shell. Spirtdesigns has been designing boats since about 2000 using these techniques and has a very good understanding of how to design fast build cats.
The jpegs give the idea. The PDF is the specifications, many drawings and jpegs of the 3 cabin version.
