POE 630b
Attached is a sketch of my modified Plank-On-Edge concept.
After realizing that the original had an S/D of only about 5.3 instead of the 10.5 intended, I thought of increasing the Sail Area (SA)to the S/D of 10. 5 amount. This would mean doubling the SA. Without using a huge amount (maybe as much as 90%) of very dense ballast, I wasn't confident that this could be done successfully. Also, there was the problem of overly tall masts and long booms.
I suppose the Victorian Plank-On-Edge racers were for racing only and were primarily day sailors. They likely raced only in good weather. Being day sailors, they would not need much carrying capacity. Maybe just enough for their crews and supplies, such as an anchor, some water, some beer, and perhaps a bottle of champagne, in case that boat won the race.
This boat would be required to carry quite a bit of stores and gear. So the portion of the total displacement, allotted for ballast, would have to be far less. Maybe just half. And the sail rig would have to be manageable too, especially in rough weather. These two requirements pretty much limited the SA. So I ended up with an S/D of only about 7.1. And this was after increasing the counted SA by about 15% and decreasing the Displacement by about 20%.
This is bad but, it may not be as terrible as it seems. Other than the rudder and a small skeg, there are no appendages on this boat. Appendages have double their surface area as whetted surface. So, my thinking goes. If the the Hull itself can act as a the keel, the over all whetted area may be reduced, even though the deep, squarish sections of the Hull have more surface area than a more conventionally proportioned Hull of a more conventional shape.
Add to this the enormous Heft Factor (Hf) of 6.3 (4 to 6 times that of a typical sailboat) and the relatively sharp ends, and we get a considerable amount of momentum to power through a chop. This may make up for, at least to some degree, the very low S/D. But I certainly wouldn't want to be stuck in light wind conditions on this boat.
The next question should be if this boat would be sufficiently seaworthy. I think it might be. This is even though it is far on the comfort side of the comfort/seaworthiness overlap. Hopefully, there is enough buoyancy in the ends to prevent it from being constantly pooped, or constantly burrowing into waves. Hopefully, as well,the flat bottom would dampen pitching to a tolerable degree.
The amount of amid ship free board is half the draft. This I think is a more healthy ratio. The earlier drawing (see next attachment)has a somewhat lower proportion. The danger of low free board on a narrow, deep hulled boat like this is that, when it heels as it must, the deck edges dip under the water. And if they do that too far, the water can come too close to the center line. This would not affect stability much. But open hatches and ventilators, even if placed on the center line, would be in excessive danger of taking on water.
This version of the concept is technically not a true Plank-On-Edge. The mid-section is not deeper than it is wide. It is exactly the same. But it looks like a Plank-On-Edge when viewed from an end. And it has almost all of the qualities of one, both good and bad.
For the good qualities:
It will not roll quickly. The flattish, near vertical Hull sides will dampen a roll maybe even more effectively than a long, shallow keel would. It would also have an 180 degree range of positive stability. It would simply refuse to float upside down. On top of that, it would be nearly impossible to capsize. And, as mentioned before, it would have plenty of momentum to plow through a chop.
For the bad qualities:
Because it would be so reluctant to roll away from a wave, that very same wave would tend to wash over the deck. And, in so doing, could very well carry away anything that is not held brutally secure. And this is especially true with deck crew. This is a boat that would be best sailed in rather than sailed on. And the decks, house, and hatches must also be strong enough to take a brutal pummeling. The Hull would not be as easily pushed aside by a breaking wave as that of a more conventional type might be. It would be rooted in the sea.
And, as mentioned above, it would do very poorly in light wind conditions.
It would be more like a submarine with sails on it than like a more conventional cruising sailboat. There is very little internal volume for its length and weight. And there is very little deck space.
But I think it would do very well in the motion/comfort department, which it was conceived for.
I might one day build a 1:12 working, scale model of it, just to see how it would behave.
Any thoughts?
