These rescue boats don't seem to me to be a good template for a pleasure craft, especially if you intend to potter around at 8 knots most of the time. At that speed they are much less efficient than a boat purpose-designed to run at that speed. You will pay through the nose for the ability to 'dash' home at 17 or 18 knots when the weather turns. The aim of these boats is extra speed to get to the trouble more quickly than the traditional lifeboats, and to do so without bashing the occupants senseless. They are designed for conditions where prudent pleasure boaters are not on the water. I'd be looking elsewhere for inspiration, possibly at small pilot boat designs, where a turn of pace and good sea keeping are both required.
My son has got an adventure Motorbike, the BMW 650gs single, and it's a bit like a boat in that it has some major compromises. It's got a pedigree like the RNLI boats, and it won the Dakar rally several times.
It's a single for lightness, but isn't very light at 180kg.
Because it's a single it has to be long stroke to get the torque.
Because the stroke is so long the cylinder head sticks up into the petrol tank area.
..So they have moved the tank underneath the seat, and put a dummy tank in it's place with the airfilter, battery, electric gubbins etc..
So what's the point?
They have gone to the ends of the earth to produce the ultimate bike!!!
The Shannon design has used similar criteria, it could be adapted into the ultimate 'Adventure' boat for exploring the world, capable of 'looking after itself in all conditions' as the designer stated.
My ideas to make this concept affordable:
The aft hull form is a straight forward planing vee, a private owner would not need the beaching capability the the lifeboat needs. Dump the £200k jet drives and hang a couple of shaft drives on 'p' brackets in small tunnels: there will be a small draught increase but you will gain massive efficency at slower speeds over the jets.
Reduce the max speed from 30kts to the high teens, twin Cummins 250hp mechanical fuel injection diesel would be perfect, the brand new ones made in Mexico classified as reconditioned. Guess 15 to 18kts max.
The big problem.> the hull is foam sandwich bagged and cured with heat.
Any idea's?
