Unusual center console design: Twin hulls forward, single hull aft (1987 MXI 21')
ziper1221
Junior Member
Joined
May 3, 2018
Posts
66
Reaction score
15
Location
florida
I came across this unusual looking boat. Seller claims it to be a 1987 21' manufactured by MXI. I'm guessing that it doesn't work so great, based only on the fact that nobody else copied it. And judging by the low hours on the old motor, nobody liked taking it out either. Google searches only bring up listings of the same boat for sale from a few years ago. Any guesses as to how it actually handles?
That certainly is a rather 'unusual' design.
I can sort of see their approach to the design (re the cat concept, lift generated under the bridgedeck, hoping for good economy), but it does seem like it was not successful, otherwise there would be more of them around.
Re the photo of the boat afloat, it is a pity that there is not a proper broadside view - however it does look like she is deeper in the water at the stern than what she should be, and I doubt there is much freeboard in way of the engine pof.
I found this one for sale in 2015, asking $2,000 -
https://www.thehulltruth.com/boats-...-mtx-aka-mxi-center-console-project-boat.html
The MTX folk also built more conventional power cats like this 27' version with twin 175 hp O/B motors -
https://www.thehulltruth.com/boats-...27ft-mtx-catamaran-motors-under-warranty.html
Looks like someone with a chopper gun and a love of the 60's batmobile had too much energy. But maybe it handled... Adequately?
Looks like someone wanted a 3-point hydroplane in an overweight underpowered center console build. Horses for courses...
I think I can understand what they were aiming for;the sponsons forward will presumably maintain the pressure peak that planing generates.On the other hand,the projecting points at the aft ends of the sponsons are likely to be vulnerable to chipping and chafing.I suspect the biggest negative thing is the strong probability of very nasty slamming with that hull form.The weight of all that stainless steel in the canopy at such a height won't be doing the boat any favours either.I can't imagine getting it back on the trailer would be the simplest of tasks,even with the guide poles to help.
Well, check it out. I stumbled across a bigger version of pretty much the same idea, ostensibly made by someone else.
"33' Defiant Catamaran
Are you looking for the stability of a cat, the speed of a race inspired V-hull, and the weekend-ability of a cuddy or express? A steal indeed, a perfect vessel for someone looking for a one of a kind gem. This stands apart with a massive deck with plenty of room to accommodate diving or fishing excursions. With the extra large 220 gallon fuel cell she is ready to take you anywhere. Vessel needs 30" shaft outboards. Endeavor Catamarans only built a few of these, and this one has barely any time on her hull. All composite, no wood construction on a cored hull means she is fast and rugged. Float on custom trailer included with this boat. Builder: Endeavor Catamarans Designer: Bob Vincent LOA: 34 ft 0 in Beam: 10 ft 0 in Fresh Water Tanks: 1 Fuel Tanks: 220 Gallons Holding Tanks: 1 Number of double berths: 1 Number of heads: 1"
M20 scows (sailboats) have something similar but a lot more sophisticated. That concept worked pretty well for the scow type sailboat but it was not much if any faster than a similar sized boat, the C scow, that does not have the tunnel .
Looks like a bizzaro world deep v picklefork. Wonder if video of it running along exists on YouTube....
