If it's not for preventing leeway then I think the design approach is flawed. Either you make a slim hull and put a pod on it in which case the pod is shorter then the hull and well above waterline, or you make a "lightbulb" stepped hull in which case the stern has enough underwater buoyancy to keep the step above water when heeled. what I see here is a very large pod put on a to small hull.
If I would want a small cockpitless "coffin-type" tri I would try to design something like a completly closed tremolino. That would give enough interior volume without getting me into trouble with stern buoyancy.
