bigfish3x
I'm going to respray the metal flake gel coat on my bass boat. I read some where that I don't need to add hardener That I'm supposed to just let is dry naturally before I shoot with clear. Is this the correct.
I was under the impression that you don't add the wax additive until you apply the final coat of clear. Is this correct.
But the thread I read on this website gives me the proceedure that the skeeter bass boat company does. He says that they told him to first fill your mixing container 3/4 of the way up with a mixture ratio of 1/2 of that with clear gel coat the other 1/2 with a high gloss additive then you fill the last 1/4 portion with the Poly Flake and then add the catylist and then to let it dry before spraying the clear.
Does this sound like more of the right thing to do? As apposed to not using an catalyst. Also as for the hardener do I use MEKP.
Thanx in advance!
Thanx in advance!
