Hi Par. I have not had time to progress the transom. Yesterday I gave it a good coating of thinking about, and in the middle of the night i started sketching it. Unfortunately I couldnt be bothered to get up at 4am and recover work laptop with CAD on it from car, so its probably the worst drawing in the world, ive knocked up. Even worse was the previous effort on my daughters ipad and crayola app
My concern is, basically the ply was only a centre section of transom. The edges are solid GRP, and solid grp bridges gap between deck upstand and hull, and deck and transom, and hull and transom.
The boat has a moulded deck design, with foam snadwich, and solid corners at transom end only. There is very little hull for me to tab too, just the centre, below ply, this goes forward about 10" until tank bulkhead If I were to cut deck to gain access to hull, parallel with transom, I would only gain around 2" of transom area to tab, and would also hit the 1st foam stringer (which is dry). The strength in the undisturbed monocoque is concerning me.
Along the deck upstand, the solid corners go forward about 2", then the deck to hull upstand is hollow.
I have not disturbed the solid glass corners, and the skin perimeter finishes shy by about 1.5" before the solid edge, so can I just replace the ply, with like for like size, and take the glass to the corners, with a suitable taper??
Not shown on drawing was a horizontal half round foam cross support, which ran across 3/4 width of transom. This was encased in 1/2" laminate and tapered off to edges, to the solid grp. Additionally where the lower edge of ply ends, there was also a foam taper, which was laminated over, and created the transition to solid grp again.
Any ideas, much appreciated,
