A short one about a person who was inspired by some racing catamarans that were designed by Lock Crowther. The Cox 45 “Hurts so Good” appears to be similar to cats like Top Gun etc. The aim of these cats are performance first, cruising capability second. People think cats like this will be cheaper and faster to build but in the real world they end up being about the same cost and build time.
The Cox 45 is 44.3 x 23.3 foot with a estimate displacement of 11,000 lbs. The aluminium mast carries an unknown sail area but has carbon sails and several spinnakers. The length to beam on the hulls look about 14 to 1. The draft is listed as 1.5 to 5 foot over the daggerboards and lifting rudders. The engine is a Yamaha High Trust outboard of 25 HP running unleaded fuel. Fuel tank is 25 Litres. The electrical system has AGM batteries and Solar Panels: 1 x 125W + 1x 80W.
The accommodation is mainly in the central pod cabin. 2 single berths laterally forward, a small dinette with a “small” double berth on 1 side and a small galley in the aft corner of the pod cabin. To give a feel for the galley a stove: Metho 2 burner, Water Tanks: 50L and a Fridge: Waeco 50 Litre. This is a minimalist cruiser. There can be a single berth in each hull but no real cabin space.
The construction is strip plank cedar, e-glass and epoxy. There would also be plywood bulkheads etc.
Its good that different designs are done and built but please be clear about your intentions. If you want a racer build a racer, if you want a performance cruiser design and build that. But when you have a racer that you try and convert it to a “fast cruiser”, the limitations of the accommodations become frustrating over time.
The jpegs give the idea.
