Doug Lord
Flight Ready
- Joined
- May 26, 2009
- Posts
- 16,679
- Reaction score
- 354
- Location
- Cocoa, Florida
Fire Arrow Foiling System Testing and Development
In one of the wildest things that has happened in a while a guy on another forum discovered that Maserati is the FIRST fullsize trimaran to use a lifting foil on the daggerboard in combination with an UptiP foil on the stb ama!!!!!
Very similar to the Fire Arrow configuration conceived of 6 years ago and tested successfully in light air two years ago!
Heres what the Maserati guys say about the Fire Arrow system-it may sound familiar to anyone that has read this thread:
First* trimaran in the world to fly with effortless stability on the horizontal loading-bearing surface of her centerboard, Maserati Multi70 brilliantly puts into practice Guillaume Vernier and his Team’s idea of flying on three resting points using a load-bearing centerboard, L-foil and a rudder instead of the two rudders and single foil adopted on America’s Cup cats.
Giovanni Soldini and his Team are engaged in a new challenge as they endeavour to turn Maserati Multi70 into the first ocean-going flying trimaran. An ambitious project that spans not just Guillaume Vernier’s excellent work (he worked on the modifications to her appendages) but also over 4.000 nautical miles of sailing clocked up by the Team this summer.
The straight central daggerboard plays a revolutionary role in this new flying trim as the horizontal load bearing surface at its end generates lift, raising the boat out of the water. “When Maserati Multi70 rises up on her lateral foil and rudder, the daggerboard wing acts as a third resting point – the central and largest one”.
Tests in wind of 40 knots have demonstrated that Maserati Multi70 is now much more stabilized and able to fly in conditions unthinkable before. Safely tackling also big seas.
* Fire Arrow was the first trimaran to use this configuration!
