Any tricks for shaping the elliptical tip? I've only ever made straight foils before.
Here is a simpler drawing. I would be more inclined to add extra layers of cloth and resin at key locations, sanding the wood back if needed, than to attempt slotting and letting in heavy G10 at the trailing edge.
Does your CAD give you a volume estimate on that drawing? I'm considering some other materials and I want to get an idea of weight.
Cheers
Z
If I bring in Wet Feet's data, convert units, merge into a solid, etc...
Volume = 1448.59407 (+/- 2.2e-06) cubic inches
And then go back to mine in Fusion, find mistakes, etc:
GRP=volume 319.9 in^3, density 1.012 oz/in^3, mass 323.6 oz
Paulownia=volume 1356.7 in^3, density 0.165 oz/in^3, mass 223.9oz
Total= volume 1676.586 in^3, density 0.327 oz /in^3, mass 547.5 oz
This leads me to believe that there is something amiss in my previous numbers in posts 13-15 and that my CAD is carrying a bit more volume than Wet Feet's. Looking at the data side by side it all seems plausible. Wet Feet data is in purple on the left, Tops is in gray on the right.
.View attachment 198652
You're getting what you pay for, at least from me![]()
The Freecad example I posted quite a bit earlier in the thread has a volume of 0.00346 cu.m. If you get the FCInfo add-on it will determine these things quite easily but be aware that the numbers will be in the chosen system units,which in my case are millimetres.In an ideal world you would have a laminate thickness to refer to and could offset the surfaces by that amount to arrive at the core shape.
@Zoro hope you feel better soon!
@wet feet thanks for the vote of confidence. I ran a new NACA0012 out and did a Sweep 2 edges and attached my previous cheek with a new loft and got this:
Volume = 1419.38363 (+/- 1e-06) cubic inches
