Note: This feature may not be available in some browsers.
A couple of points to ponder; 4 plies of cloth will give you an implement you can fell trees with,its a bit heavy for a sheathing layer on a structurally adequate core.Second,given the curved leading edge,it won't be possible to wrap the plies as they will need darts cut to conform to the shape.Wrestling with slippery,resin coated cloth and manouvering the sticky whole over to work on the other side is no fun.Something so critical to the operation of the boat isn't an ideal candidate for a learning exercise in infusing but it might ultimately be a good choice of method.
Before reaching that stage I might suggest using biscuits to align the strips when gluing the blank together.Also keep in mind that adding half a dozen or so sash cramps may impose enough of a load to lock in a downward set if the support isn't carefully arranged.
finger sketch, 4 layer laminate, relieve core for overlapping section all the way around the end, stagger each layer 20mm min, one corner drawn, build 4, build upside down against drawing, set part on jig to allow wrap. If the laminate misbehaves doing it by hand, plastic wrap over peelply or laminate and wrap with masking tape and secure plastic to ‘bottom’, with 8 layers of glass on the end, you may decide 3x db1200 is enough and then the ends are still 6 …
wrapping the section will be a nightmare, as the glass will distort too much
Hey guys, thanks for the efforts. I'm sailing for the next couple of days, season open down here, I will be back soon.
I had a bit of free time and wanted to see if I could create a CAD model of the rudder in question. It's a bit rough and ready but shows the useful features. You may need some suitable software to open it-most 3D software should cope with step format or if you don't have it, download Freecad which costs exactly what you might hope from the name.
I had a bit of free time and wanted to see if I could create a CAD model of the rudder in question.It's a bit rough and ready but shows the useful features'You may need some suitable software to open it-most 3D software should cope with step format or if you don't have it,download Freecad which costs exactly what you might hope from the name.
