Personally I like the Scarab range, more sophisticated build but as they say, "you get what you pay for "
http://www.teamscarab.com.au/index.html
I dont support this argument. Sure, the Scarab may look a little more "production" and less boxy (I personally think the strike looks awesome), but here are some basic numbers I run on everything these days. I wrote my own Texel Ratings/Bruce Number calculator in Python. While these numbers do not indicate everything, they give me a base idea of the performance aspects of each design. Here are the outputs as follows.
Scarab 18:
weight = 345kg
length = 5.51m
sail area (main + jib) = 22.8m2
Texel Rating = 147.3668970370803
Bruce Number = 1.7162610380799437
sail area (main + spin) = 31.5m2
Texel Rating = 129.49400303545696
Bruce Number = 2.017303289951323
Strike 18:
weight = 250kg
length = 5.5m
sail area (main + jib) = 19.1m2
Texel Rating = 142.49331726935216
Bruce Number = 1.7488757895374496
Sail area (main + spin) = 28.5m2
Texel Rating = 121.41431666467759
Bruce Number = 2.1363121576380975
The numbers for the Strike 18 indicate it using the Quatro16 rig. These numbers were based off of the study plan numbers and the screecher Richard uses on his own boat. Richard used a cut down Tornado mast with a totaly height of either 25.5 or 26ft IIRC. I bought a nacra 5.2 (with a smaller mast) for my boat and my mast height is 28.1ft (hobie 18?) so with the Strike, you can increase your SA a little but you may be reefing sooner than other boats.
I like Team Scarab's boats a lot. But their numbers just dont show what I like to see, especially for all the effort of foam sandwich with moulded grp akas.
