Wa'apa Outrigger Sailing Canoe Build
Discussion in 'Multihulls' started by John Bjorklund, Nov 11, 2025.
  1. John Bjorklund
    Likes: 9, Points: 8
    John Bjorklund Junior Member
    Hello fellow sailboat enthusiasts. I am going to document my Wa'apa sailing canoe build here to share my progress and get good advice from you all along the way. I have already posted several questions on this forum so thank you for everything.
    I am building the 16' tacking plan designed by Gary Dierking. I actually started building this boat over 8 years ago. Don't laugh. I moved away, left the boat but finally brought it here to finish!
  2. John Bjorklund
    Likes: 9, Points: 8
    Here is my tiny boat shop. But it works.
  3. John Bjorklund
    Likes: 9, Points: 8
    Storage racks. What I really like about this design is the hull breaks in two for easy storage.
  4. John Bjorklund
    Likes: 9, Points: 8
    Two coats primer. Three coats Rust-Oleum top side. Easy paint to use. Flows nicely.
  5. John Bjorklund
    Likes: 9, Points: 8
    I built the leeboard years ago out of mahogany and poplar. In this pic I'm testing how it mounts.
    Don't trash me for using poplar.
  6. John Bjorklund
    Likes: 9, Points: 8
    Found this aluminum plate on Amazon.
  7. John Bjorklund
    Likes: 9, Points: 8
    Installing the aft seat.
  8. John Bjorklund
    Likes: 9, Points: 8
    8 coats of Total Boat Halcyon spar varnish. Looks like a sexy cutting board.
  9. John Bjorklund
    Likes: 9, Points: 8
    Made a knob out of wood to tighten the leeboard down to the hull. I glued in a nut to screw onto the leeboard pivot bolt.
  10. BlueBell
    Likes: 1,233, Points: 113
    Looking good!
    John Bjorklund likes this.
  11. kapnD
    Likes: 540, Points: 113, Legacy Rep: 40
    kapnD Senior Member
    I’m betting your neighbors hate you!
    What did you use for primer under the Rustoleum?
    I’m impressed with the performance of that paint, and am contemplating using it as a deck coating over non gelcoated fiberglass, want to be sure that the bond is good.
  12. John Bjorklund
    Likes: 9, Points: 8
    Ha, my neighbors haven't complained yet and I try to use hand tools as much as I can.
    I use the Rust-Oleum primer. It's dusty as hell when sanding. Overall, the Rust-Oleum topside paint has really good reviews. I don't know how it performs yet personally other than it rolls and tips very well and smooth. It's also very budget friendly.
  13. John Bjorklund
    Likes: 9, Points: 8
    Mast step with some lovely curves. I'm almost set on going with the Mini Fish lateen sail rig. At 66 square feet, its about 10 square feet larger than recommended by Gary. From what I understand, this boat can handle a bit more sail area.
    BlueBell likes this.
  14. Zilver
    Likes: 16, Points: 8, Legacy Rep: 14
    Zilver Junior Member
    If you use the minifish rig with standard mast, the mast may be to weak because of the bigger righting moment of your boat. For my kind of similar outrigger boat I used an old windsurfer mast, with a second cut off windsurfer mast stuffed in the lower part. It's a landsailor trick I found somewhere on the internet. It works well. The mast is a bit bendy, but not too much, and doesn't break. little tri surfmast.jpg
  15. John Bjorklund
    Likes: 9, Points: 8
    @Zilver you have a good point. My plan was to make a laminated wooden mast and spars (fiberglassed up 5ft.), and not go with aluminum. What are your thoughts on wooden spars?
    I entertained the idea of using windsurfer masts but I have a hard time finding them.
    Nice boat btw!
