KD8NPB: So, epoxy it is! But I can't find LTM 3610. Can you source it? I did read where chopped strand mat is not compatible with epoxy resin. My guess is that it is hard to fully wet out with epoxy, but I am not sure. I did read where Knytex X-Mat is compatible with epoxy. And I have successfully used it with epoxy in the past.
How can you vacuum bag an object that you only have access to from one side?
Exact nomenclatures vary by manufacturer, I use Vectorply material a lot, so I use their part nomenclatures for fiberglass. What you're looking for is a lateral & transverse material, e-glass, 36 oz directional glass with 10 oz/yd nominal of stitched chop on the backside.
A pure lateral and transverse material could be used, but the chop layer is really needed to decrease the possibility for interlaminate shear.
Some chop strands can be used with epoxy, but mostly the answer is "no". The chop that comes prestitched on to the backside of material like BXM1708 or LTM3610 is OK because they are not treated with chemistry that is specific to UPR/VE resins. Rolled chop-strand mat is usually treated with an emulsion to hold it together, which is styrene soluable. The problem is that epoxy has no styrene in it. Stitched mats with chop stitched to the back is stitched mechanically together...there is no chemical emulsion.
In order to make things cheap and easy on you;
Buy some 5:1 epoxy based on what temp you're working at.
Buy some 1708
Follow the 3 x layers of BXM1708 that the other user recommended.
Cut the 3 layers identically, BUT.
The middle layer, rotate it by 45 degrees before you cut it.
That way, you have the long fibers in 0 degree plane with the stringer, as well as some going 45 degrees.
Effectively what you would have is 6 layers of material.
a thin layer of stitched chop
+/- 45 degree long fibers
0 / 90 degree long fibers
+/ - 45 degree fibers
Don't worry about the vacuum bagging, it took me months to get good at it, and I made a lot of garbage before I did.
