Rhino/Flamingo rendering help !
Vibtor
Sep 29, 2004
10
Norway
I use Rhino/Flamingo for boat designing.
Is there any way to make a total transparent background when rendering ?
The big question here is - what's on the other side of a transparent background?
You could try just having a background image...
Rhino/Flamigo rendering help.
I use to copy the rendered images into Photoshop. Then i do not want any background at all. Now i have the problem that a squared "solid" background follows the image and covers other images on the same "sheet".
best reg:
Vibtor
With a solid background you should be able to select it with the magic wand tool in photoshop and make it transparent there.
Go into Flamingo "environment" settings dialogue box.
put a tick in the "alpha channel" box.
now once you have rendered the image you can select he background in photoshop using the alpha channel.
look under flamingo and/or photoshop help for more info on exactly how to do it. (its well worth the five minutes it takes to learn about using alpha channel).
Good luck,
Rob
