pironiero
Coping
- Joined
- Apr 26, 2020
- Messages
- 285
- Reaction score
- 21
- Location
- Pattaya, TH
Note: This feature may not be available in some browsers.
I already have a hull shape I’m happy with, but I’m not sure about its submerged area shape under heel. I guess I need some calculations — I definitely don’t care about renders. Also, since English isn’t my first language, I’m not sure I fully understand what you mean by ‘offsets.’Depends on what you want to get out of the work/time put into the drawing. Offsets, renders, calculations, etc...
From a price and learning standpoint you can't beat a board, square, triangles, rule, and splines. If you don't need millimeter precision (especially at the intersection of two curved surfaces) there are some free to use software on the net, and all come with differing advantages, limitations, and learning curves.
Isn’t it a bit too old? The year 1993 seems pretty ancient in our rapidly developing software era.Since you already have a hull what you need to do is to pull the existing offsets. Try this resource.
Boats: A Manual for Their Documentation FREE e-Book https://schoonerchandlery.com/shop/misc-2/schooner-chandlery-picks/free-e-book-boats-a-manual-for-their-documentation/
And therefore you shoud not be speaking Thai and doing math. The language and math was developed by people long ago who knew nothing about computers and by your logic make it irrelevant today. (roll-eyes). A computer is just a tool, and like a power saw to a hand saw neither better or worse, just different.Isn’t it a bit too old? The year 1993 seems pretty ancient in our rapidly developing software era.
Then why learn an obsolete tool while you can learn a modern one?And therefore you shoud not be speaking Thai and doing math. The language and math was developed by people long ago who knew nothing about computers and by your logic make it irrelevant today. (roll-eyes). A computer is just a tool, and like a power saw to a hand saw neither better or worse, just different.
Big thanksTo answer the question/title of the thread, and as an user of Rhino back in university, now on work, extensive in my free-time:
YES
and definitevely yes when you already have a hull as Rhino might not always be the best for hull modeling
This is what makes you a hobbiest and not an experienced professional.Then why learn an obsolete tool while you can learn a modern one?
Would you pick a hand drill before power drill to do a thousand holes?
PreciselyThis is what makes you a hobbiest and not an experienced professional.
I would never pick a power tool over a hand tool simply because it is a power tool; I would choose the right tool for the job. I think the problem is that you belive that all computer program algortihms are the same and correct simply because they are from a computer; where I know that this is incorrect. The descretation required for digital solutions cannot exactly model a continious hull shape....it can be good enough, it can be close, but it will never be exact.... and you need to use many different programs until you find the one that suits your needs. RHINO is a great surface modeler, however it needs extensive pre-processing to enter a table of offsets and some plug-ins or post-processing to generate hull offsets and hydrostatics (depending on which version you have). If you have an existing hull, it is better and faster to take the lines off and calculate by hand/spreadsheet than it is to try and torture RHINO into getting it correct. Or if you whish to be professional, spend the money and use photogrammetry.Then why learn an obsolete tool while you can learn a modern one?
No, the picture in the first post is just a photo of Kaori 6.50 by a builder I've been following on LinkedIn.In my yacht design classes, we got the hulls as IGES or similar files from Maxsurf or Delftship and 'finished' them in Rhino3D, adding the final bow, decks, house,cockpit, and transom. We were graded on how the 3D boat matched the supplied 2D views and if the CAD was 'watertight', surfaces properly formed and trimmed together. The results were not enough to build a boat but enough to render one.
I have 'designed' (enought to render) a bigger boat in Fusion(360) using the table of offsets from its 1940's blueprint, similar to the fishing boat in my avatar.
@pafurijaz here on the forum has done many designs in many different softwares.
Rhino3D is very nice for surfaces and is pretty powerful out of the box for file import and export.
Is the hull shown in post #1 the hull that needs to get back into the computer for analysis? Was it started/ever in a a computer?
If not, taking offsets manually via older methods and running those numbers back into Maxsurf, Delftship, Carlson, etc. might get the hull back to being able to be subject to analysis.
