Chesfisherman1
- Feb 12, 2019
- Messages
- Maryland - Flordia
Hi All,
I am in the planning stages of refitting my 2010 15ft Flats Boat and need input (or therapy).
-Boat Background:
AS-IS: I have a true "Free Floating" flexible boat hull/Egg shell that balloons which fail sooner than later. Last month, I cut front portion of deck out and drilled 4 6" access holes in the rear deck and by the stern/transom for visual inspection. Results-
Stringers
1-I want to install a stringer system that effective and active. (ie. coosa or arjay).
2-Bulk up hull for strength.
Thanks,
Chesfisherman
-Boat Background:
Length 15'
Beam 7'
Transom Height 20"
Max Horsepower 70hp (Have Honda BF50 ~210lbs)
Max Persons 4
Draft 6"
Weight 600 pounds (not sure if this is with engine/fuel tank/etc)
Beam 7'
Transom Height 20"
Max Persons 4
Draft 6"
-The hull is from a production mold with Gel Coat then 2 or 3 layers of fiberglass mesh
-The stringers are foam with a white plastic base and were glassed into hull with 2-3 layers of mesh.
-There appears to be no structural bulkheads that perform a hard bond of the hull to the liner.
-The deck is PVC core.
-The hull to deck/liner bonding was performed with a considerable amount of structural putty. (still hard as a rock)
-the last addition was flotation foam (not sure if 2/4/6 lb) through out hull/liner voids. No foam or reinforcement from chine up the rub rail hull/liner join.
-no/low putty bond hull/liner
-failed stringers-wet and debonded
-stress cracks inside perpendicular to stringers
-stress cracks inside longitudinal in high flex unsupported areas.
-stress cracks on outside gel coat skin-mostly longitudinal.
-prior owner "fixes" were not small, appeared structural with a cosmetic fix.
Questions:-failed stringers-wet and debonded
Stringers
1.a Is this a dumb move given my hull is an egg shell? (see 2 where bulk up hull is discussed)
1.b If not too dumb...is there a buffer material used between the "hard" stringer material and the "soft" hull that will decrease hard spot issues?
Hull1.b If not too dumb...is there a buffer material used between the "hard" stringer material and the "soft" hull that will decrease hard spot issues?
2.a Is a hand lay up of CSM/1708/Kevlar/1708/CSM on the exterior over kill?
2.b Can interior structural reinforcement be performed with stringers/bulk heads, hull/liner bonds with Plexus MA, and a final 8 lbs floatation foam under deck...without doing hand layup discussed in 2.a.
I would appreciate any/all feedback. Trying to schedule a trip down to pop the cap for refit and want to ensure I don't under or over kill this project. I not trying to make my 5k skiff a 35k hell's bay...but i would like it to be safe and structurally sound.2.b Can interior structural reinforcement be performed with stringers/bulk heads, hull/liner bonds with Plexus MA, and a final 8 lbs floatation foam under deck...without doing hand layup discussed in 2.a.
Thanks,
Chesfisherman
