Folks,
I'll try attaching the original article where the graphs have scales! It would be very interesting see experimentally, if a leading edge add-on would increase the control authority of a flat plate rudder. Xfoil thinks so, since the stall angle greatly increases.
The suggestion to fit turbulators (zig zag tapes) to a flat plate rudder is intriguing. Expecting flow separation to occur right at the nose, fitting the tapes aft of the nose might already be too far downstream. If I was to try this, I would scratch vertical grooves in the rounded nose of the rudder (one heavy pass with 40 grit paper?). I would not expect (based on Xfoil results) as much improvement as with an elliptical add-on nose.
The experimental evidence that I have for improvement to my centerboard is somewhat indirect (GPS ground tracks, helm balance, ability to "hold a lane" against other boats). One of my colleagues want to rig the centerboard out the side window of a car, put tufts on it to observe the flow, and drive down the road at ~80 mph to hit the right Reynolds numbers! There are some things we won't do for science.
Mike Raleigh
