The easiest approach would be to cut off the small, damaged trailing edge corner, seal (epoxy), sand/taper, paint. Questions:
- Would the slightly altered new shape disturb water flow enough to cause noticeable vibrations at higher speeds?
- Is it worth the effort to do a proper reconstruction of this small area?
Thanks for any
Thanks for any
