Effect of moving max thickness on a keel or rudder
So, if you are going to shorten the chord, do it at the hull end?
Yes, and thin it also. See Hoerner Fluid Dynamic Drag for a discussion of interference drag caused by strut to body or strut to strut joints.
Ah, I hadn't considered that. Of course that's why the thickness control station was added on the keel stub. I faired a keel on a J24 way back in the 80's. In that case you couldn't really touch the keel stub at all. I didn't concern myself with the keel shape at the time, just borrowed some templates, but I think the keel was moved forward several inches. A ton of work, but it dramatically improved going to windward. I understand the J22's are much closer than the 24's were, but there are still a pretty wide range of keels in the fleet.
I've got some reading to do.
thanks.
