Yobarnacle
Senior Member holding true course
- Joined
- Nov 10, 2011
- Posts
- 1,749
- Reaction score
- 133
- Location
- Mexico, Florida
Note: This feature may not be available in some browsers.
I have added a few photos (hopefully they loaded up) of the offending areas of veneer, also one that shows that my entire yacht is not in such a disgraceful statelol
Essentially it is just a few areas in the aft cabin, port and starboard, essentially identical. As can be seen, the area on the hull (portal) needs re veneering, also a few bulkhead areas, the veneer has peeled off and most likely will come away complete with a little care. I have decided that most likely the section to the right of the portal above the nav table I will finish with lamipanel. I will actually be replacing all the old headlining with lamipanel.
As can be seen, it really must be completed insitu, hence no vac bags or complicated systems, as I can not remove to undertake.
The areas are not huge and wide, so applying strips of veneer either with heat activated or cold glue would suit I think. Andy, making my own veneer sounds like a nice project, but simply not practical, and the expense would not warrant the outcome. I also do not require a showroom finish, but something that looks clean, tidy, practical and esthetically pleasing.
All the information received is so appreciated, It makes life easier, I am able to take bits and pieces from replies to put something practical together.
