PatrickARiva
- Feb 18, 2025
- 14
- Ontario, Canada
Hey guys,
I'm working on building my first boat, a Jim Michalak Piccup Pram.
I'm doing pretty good right now, over the winter i've build what i could given the weather.
- spars
- mast
- boom
- leeboard guard and guide
- tiller
- working on completing the sail right now.
I've been looking over the rudder construction and i like Jim's simple concept
but i dont really want to do the lead counter weight, im not setup to do lead melting. I've read about others using bungie chord or springs but i've also heard of others using a downhaul and the uphaul method.
The current method has the pull up which i understand but i'm trying to understand how to ropes can hold it down under sail. When i see the photo below, it makes me think that when lowered the two lines help each other out in tension and not allow the rudder to kickup when under sail but then how does it do it when in an emergency if hit with sandbanks or shallow waters. It seems this version below may be using a breakaway cam cleat for that emergency scenario, correct?
Can anyone help explain to me how i can make this happen without the use of lead counter weight?
It seems with the photo above it would be possible, does this make sense?
Patrick
- spars
- mast
- boom
- tiller
Patrick
