oldsailor7
Senior Member
- Joined
- May 10, 2008
- Posts
- 2,097
- Reaction score
- 45
- Location
- Sydney Australia
After four years of sailing on two different Trimarans, I got fed up with foam of any kind for floatation, for reasons already stated.
I considered ping pong balls
But realised after two secs consideration that in the event of a ruptured hull, however small the rupture, the ping pong balls would become escape artists.
I then considered milk jugs but they would not be much better unless locked in foam, and that would be a really messy job.
Finally, in my Bucc 24, I used 4 gall Acid bags, which can be crushed up and inserted in the spaces between the frames in the Amas, inflated with a vacuum cleaner in reverse, allowing the pressure to equalise before screwing on the caps. This provided enough flotation so that even if all the hulls were ruptured, the soft and ply-able bags would not float away or be damaged, but would support the whole boat sufficiently to perhaps reach safety. Fortunately I never had a situation where I had to test this theory.
