A few points:
You'll have less draft without the tunnel (more buoyancy, right?)
Stitch and glue doesn't work as well with square builds like yours.
Why bother with an outboard when you've got the air-prop?
Hauling around 200 pounds, plus fuel, is going to increase your draft and fuel consumption.
9+ feet of beam (although it's not clearly shown) is too wide in most countries for road trailering.
Why not square off your hull at 8.5 feet with vertical sides?
It would mean less draft and easier/earlier planing.
Next drawing, include a top, side, and end view all lined up with each other showing all the features and dimensions.
I see you want to floatation fill the hull which begs the question:
Why not just build out of foam and epoxy-fiber over that?
Cheers
