Where do you want to start?
Your first problem is in defining the mast compression loads. Usually defined by rig tension and angle, halyard tension, and a bit from spreader compression. Do you want to play it safe, and use rigging BS as the tension in the calcs, or do you want to use "sailing loads" and come out with a smaller spar section that may fail before the shrouds?
Steve
