Dejay: Finally someone mentioning the fact that XPS comes in all kinds of grades. The densest XPS marketed for construction I can find is 45kg/m3, and has a compressive strength of 700mpa; seem to be the same stuff as mentioned in your table. Those properties are in the same ballpark as low/medium density foams marketed for boat building, as your table also agrees. But looking at prices, the construction grade material is still about 10x cheaper than the best deals on boat-grade foam i can find; probably just because it isnt targeting a niche market, but sold by the truckload.
What the demands on the foam are is a subtle question that requires quite some quantitative understanding of the underlying mechanics, and is quite dependent on the precise area of application and its anticipated loads. So I am not saying high density XPS is the answer to everything; but going by the numbers is sure seems like a cost effective solution for the areas that are not demanding the most from the core.
