rxcomposite
Senior Member
- Joined
- Jan 16, 2005
- Messages
- 2,874
- Reaction score
- 687
- Location
- Philippines
Somebody has beaten you to it. There is a high density foam core commercially available (the brand escapes me for a moment). This a foam core with fiberglass embedded in the core and is usually used in transom of powerboat. If you want optimum shear strength, the fibers should be running at +-45 degree angle to the base, not 90 degree. At 90 degree, you are only increasing vertical shear strength, not in plane shear. Better use balsa, it is lighter.I just thought of two possible ways to improve the shearstrength. Kind of a low cost DIY version of the stitching mentioned earlier.
If you want to improve the core shear, you have to understand the physics. Shear is greatest at the center and diminishes towards the surface. That is the first principle. Therefore, in order to optimize, use high density/high shear strength in the middle and laminate low shear/low density foam on both sides. Laminated foam anyone?
