Multihulls in general
With multiuhulls that are light enough, and if the L/B ratio is just at optimum, if the distance between the hulls is just right, if at maximum displacement the wetted surface is at minimum, you can exceed the hull speed.. you can make them surf on the water, under power or sail!
The hulls must be designed such a way as to prevent squatting!
... One more fact: if the hulls are long enough to straddle two or more wave crests, you will feel like being on a cruise ship!?!
(Exccuse me for stretching the truth just a bit!)
By the way, hobby horseing can be the sign of a not so well designed multihull, usually a result of badly placed pontoons.
(Also, too heavy superstructure, too short pontoons, too fat entry into the waves, badly placed C of G. etc...)
The super light ones will surf with a fraction of the horse power needed for a same length monohull!
Search the net for "Ultra Thin Hull" (UTH) Triamarans.
The US navy, plus the Aussies and Kiwis made some so fast, that they will boggle your mind! (Note, these nicknames have been used as an endearment!!!
They can do highway speeds without generating high waves.
All you can see is the surface foam left behind!
Talking about multuhuulls ...most people will think of the short cats and tries that you can pull up the beach.
Think in terms of well over 75' to 150'! That is a good beginning!
Talking about a short beach cat and making judgements on multihulls is like comparing the original mini to a stretched Caddy limo!
Regards,
Stephen
