Low freeboard tends to be very wet in heavy weather to the point of being quite dangerous to be on deck at times. But you'll find classics with quite generous freeboard too. As has been said already fashion plays a large part in yacht design, designs can be quite different from different parts of the worldI have questions.
Why do Classic Wooden Sailboats have a low freeboard design?
What are the advantages and disadvantages of low freeboard designs?
Its design looks almost like touching the surface of the water.
Many modern designs are caravans that sail, but light weight for higher speed, so more of the height inside, is above the waterline.
Many Older "classic designs have a heavier longer keel and are effectively narrower. So your feet in the cabin are well below the waterline, so less of the hull is above the waterline..
I believe that each ship has the freeboard that it must have to comply with its SOR or with the regulations that are applicable to it. It seems to me a banality to say that the minimum freeboard is a matter of fashion. Which designer would reduce the security, the stability, the load capacity, ... of its design by following a certain fashion ?. Absurd.
In many types of ships, for various reasons, the freeboard is intended to be the smallest possible, as previously stated, the freeboard increases the area exposed to the wind but, on the other hand, also increases the load capacity or safety of the ship. As always, it is a compromise between different options, it is never about following a trend.
Just my opinion.
