Sailor Al
- Feb 7, 2021
- 697
- 30
- Sydney
If I had a half-decent secondary school physics lab with an air table and air track, I could easily show that there is no physical "lift", only a component of the body force in the direction you want to define it in. I'd have Sailor Al and the other students make all kinds of sails and "lifting" surfaces and we would test, and track, and analyze each and every one. We would get down to the "philosophy" of the physics of "lift". But I can't do that for people on the internet when they choose to keep their mind closed.
Now you're singing from my songbook, just a little off key!
The aviation industry generally accepts that lift is the component of the aerofoil force perpendicular to the airflow*. In aviation, it is logical to resolve the aerofoil force relative to the airflow since, in cruising flight, it coincides with the vertical force of gravity, and the primary purpose of a wing is to support the weight of the plane! In that scenario, the component parallel with the airflow is drag, which has to be oppose by the thrust of the engines to maintain the required airspeed (and incidentally transport the passengers/freight to their destination!).
My issue with the use of the term lift in relation to sails is that it is illogical to resolve the aerofoil force around the airflow. The primary purpose of the sails is to provide thrust in the direction of travel (C/L + leeway). It is more appropriate to resolve the aerofoil force into thrust and ....and there's the problem: what do we call it? sideways force, leeway/heel, FLat, ... there's no generally accepted term.
But we must stop talking about lift.
*OK, I know, is it relative to the airflow, or the chord of the wing, or the centreline of the plane... that just adds to the whole confusion. Let's stop talking about wings altogether!
