WAMIT source code
Discussion in 'Hydrodynamics and Aerodynamics' started by Mike Graham, Aug 1, 2013.
  1. Mike Graham
    Likes: 6, Points: 0, Legacy Rep: 54
    Mike Graham Junior Member
  2. CWTeebs
    Likes: 15, Points: 0, Legacy Rep: 171
    CWTeebs AnomalyGenerator
    I do not believe TiMIT exists as a supported project. I am fairly certain there's no way to get any version of the WAMIT source code, it's a commercial product.
  3. Mike Graham
    It had long been my understanding that, though new versions are commercial, old versions of WAMIT were open source. The MIT website seems to suggest that indeed this was previously that case. Was it not?
    If so, shouldn't that version (not a current one) be able to be distributed?
  4. CWTeebs
    The simplest answer is no, and I think I contacted Chang-Ho Lee with just such an inquiry once but maybe you ought to do the same to confirm:
    info@wamit.com
  5. Leo Lazauskas
    Leo Lazauskas Senior Member
    It should be able to be distributed, but there is no compunction for it to
    actually be distributed. You can ask for an old copy (and I'd like one too!) but
    you can't compel somebody to spend time finding the code and releasing it.
  6. CWTeebs
    I'd like to see the source for WAMIT as well as Michlet :)
    I understand the WAMIT theory and work with a similar (low order) panel method for seakeeping on a near daily basis, but I'd really like to see what methods are employed to get numerically stable results (solving, keeping track of and then integrating the potential gradients to get forces, then RAOs, impulse response functions, all accurate across various wave frequencies).
  7. Leo Lazauskas
    Which part of Michlet? Some of the source code might be well within your budget.
