picture shows the center tap power resistor part number is 8.
The center lug is offset?
I think it is, I will thorougly investigate as I dont understand why this is putting out such high volts.
Perhaps the high and low charge side wire hookup on the resistor have been reversed? I would think the low charge side should have higher number of windings. I will check. This is a 6 ohm 225 watt wire wound resistor with 2 outer adjusting lugs.
From series field of gen, power comes into center lug of resistor. I think center lug is fixed, not moveable, only outer lugs move.
when the batt volts are low, both sides of the circuit are in.
When the batt volts rise, the 2 step charge reg K5 opens the points leaving only the low charge circuit in.
Voltage output is entirely dependent on RPM of gen, and resistance setting. Seeing RPM is steady, then resistance must be adjusted. excess output is given off as heat. HOW ABOUT hooking up a light bulb in series with low charge wire? To reduce voltage, then would also shed light instead of just heat.
If I cant figure what it is doing wrong, then I will likely disconnect low charge wire. GEN powers the AC charger which does charge the gen battery.
even though prior to spec C, it is the same part. My gen is spec C. Manual shows all the parts for spec A, B, C
I show this picture cause it better at showing the off set center lug.
The schematic and wire diagram are on page 43 here
you can full screen and zoom around to see the charge circuit, it is very simple design.
http://www.docstoc.com/docs/34443851/Onan-Operators-Manual-and-Parts-Catalog?
K5 is the two step charge relay
R1 is the center tap lug resistor
