Mcck spec E won't stay running
Tom Blizzard
New Member
Joined
Mar 17, 2020
Posts
2
Reaction score
Location
Tennessee
I have a very old 6500 MCCK spec E. The troubleshooting I've done seems to point to something going wrong with a 12-volt side. I can start it and run it and measure the low and high charging currents both at about 14 Volts for about 45 seconds. Then the DC voltage drops to zero and of course the generator stops running.
OK, so the problem is with the engine part if it won't run longer than 45 seconds. Does the power to the ignition go to zero when the engine stops?
This is a spec e Genset with solid state control. Power to the ignition goes to zero because the solid state control is telling it to shut down. It's telling it to shut down because it's no longer getting the correct high and low charge current from the generator itself. I can force it to run by pressing the Rope start switch which ignores the inputs from the generator and just supplies 12 volts from the battery to the ignition. I feel like the large wirewound resistor it's getting hot and failing but I could be wrong
Back
