WHAT?!? You can't lay it out on bare wood? I called and talk to a Bondo rep and he told me I was "good to go"..... Said wait about 3 hour (with the reduced hardener Ratio) before sanding or in my case, floating it..... Well s..... o...... b.......
Yeah, I probably just wasted a quart of resin..... Looks sad..... ....... When I mixed up the first 8oz and poured it on the boat exterior bottom, I used a clean smooth wood strip to spread it out real quick. Then I brushed it out like paint, like my neighbor suggested. And then realized that I needed about 10oz to cover the bottom. It's 8oz per side.... So about a gallon to do this little boat right I reckon.
I'm still "building stuff " inside the boat. I'm going to add another couple frames (or just bottom the bottom part) and then rip up some 1x2's into thinner strips, and run a few side by side, from bow to stern..... Like a wood slat bench seat.... ? I don't really want to sit directly on the floor...... Kinda scared.....
So I guess I need to break out a drum of El Bow brand grease and sand this mess down, and prepare to do some video watching...
Why do you say it will crack, over time? If I add fiberglass to it, and or, that fiber dust stuff my neighbor has? It's like fiberglass strand chopped up to almost like table salt.... What could I do, at this point, to help the boat last? I haven't done anything to the inside yet.
I truley appreciate the help, Par. I've been going through your posts and replies. And your site too.... I dig that 12' racer you just designed. That's pretty slick... Maybe when I learn more skills, tips, and tricks, I might revisit that in more depth. I don't like buying stuff, that I could build myself, how ever it may turn out. I always do the best I can, with what I have or have access to. I take pride in my work. And in the end, I believe I enjoy it that much more. If I lived closer to you, I'd come work weekends for free, just to learn.... I prefer hands on learning, to text and blah blah... At any rate, I know my time would not be wasted.
Happy 4th !!
