Nordic Cat
Senior Member
- Joined
- Jan 15, 2008
- Messages
- 164
- Reaction score
- Location
- South of Copenhagen, Denmark
Hell all,
I hope you won't take this badly but it is always easier to develop something well proven than to totally develop something brand new. If you want to pull the main down on a square run use good slides and no diamonds. Sail downwind most of the time with a screecher and it will furl beautifully and will pull the boat downwind by its nose.
The planform of a large genoa has lots of induced drag due to its triangular shape so along with headstay sag the benefits of having no mast in front of the luff will be nullified. Especially if you can't enjoy the extra roach a main gives you - increasing sail area and planform efficiency.
Many boats that rely on performance to sell - Melges, J boats, skiffs have large mains behind non rotating masts and do well. Even boats with rotating masts and free design rules like the NS14 and 18ft skiffs usually end with 3/4 of the sail area in the main - it has been proven to be the fastest by huge amounts of trial and error.
The large genoa monos of the 70's (S and S, Peterson, Frers) have given way to short overlap blade jibs running larger mains. Mains are easy to tune, keep their shape in a blow, sail fast and make the boat nimble in tacking. If the main was slow then the monos would still have small main rigs but they accept the loss of unmeasured sail area and make mains bigger.
You can make mainsails more manageable and I feel that your energy and talents could be better spent down this road. As stated before a wishbone boom tames a mainsail to a compliant helper and makes the rig cheaper with no traveller and large winches required.
These commments are not designed to inflame or cast aspersions on your desires. Good luck in your endeavours.
cheers
Phil Thompson
I agree with you Phil.
That is why I have chosen to use a bi-rig design with fully rotating unstayed masts, so the scene from the Lagoon described above will not happen. Let go of the main sheet, the sail and mast will rotate to feather, drop whatever sail you want, tighten the sheet and be on your way!
All this without loosing any performance, and by splitting the sail area in 2, you get manageable sail sizes. Yes, use a powered winch, or design it so you can use the anchor winch to raise the main.
For a tri, I would consider a Ballestron rig instead.
For Stefanos requirements, I would suggest 2 A-masts, one on each hull, with a furling headsail. Shorter masts = easy handling. An alternative could be a hinged mast on each hull, with stays down to the hinge that also rotate. Then a forestay and aft stay, maybe a bit to stiffen the mast and keep it in column. Even lighter and better performing.
Someone mentioned "slot effect" - this myth seems to perpetuate - can we agree that there is no slot effect, either on a fore/mainsail or a bi-rig boat!
Flow goes from high to low pressure, and a sail is 3 dimensional.
Regards
Alan
