if all else fails I'd look into publishing through Create Space.
Cheers,
Earl
Thank you Earl. You have given me another option. The site seems to be here:
https://www.createspace.com/
Will explore this as well as Indiegogo.
Regards,
Guru
Cheers,
Earl
I think I understand. See if this is close: the upstream end being held firm and the downstream end is loose. In between is a boat of some kind equipped with a paddlewheel, around which in some way the rope is looped several times so that there is effective friction. The power applied to the wheel causes it to rotate. Because the relative torque from the floats vs the spindle the boat can be pulled upstream towards the fixed end. I would guess that the loose end had some sort of attachable drag inducing device if much work was to be done.Let me quote here from abstract of a technical report (the English was a bit off, so I modified it a bit):
"When a long rope, of which the one end is fixed upstream, is adrift freely in the flow, and the other end is rounded several turns to the hoist of paddle wheel axis of a boat, then the boat can go upstream by virtue of water power. The boat is called a the paddle wheel climber."
The report is here:
EXPERIMENTAL INVESTIGATIONS OF THE WATER POWERED BOATS—ON THE WATER POWERED FERRYBOAT AND THE PADDLE WHEEL CLIMBER, Pages 583-588, M. Mori, J. Kawakita, K. Horiuchi, K. Ogawa
Cheers,
Guru
What about this vol 2 ? I would also like to become a fan .
If that means a rare bird, that is yes. Apparently available in Japanese, which I don't read, but I think the pictures would be worth the book. The English translation seems to have not been completed. If I find a source for the Japanese version, I will let you know.Thank you for the information . Locus vol.1 is a kind of white raven ?
